Show only
Search instead for
I work with concrete structures and use cubic yards not cubic feet. Trying to have this feature added in Inventor so that no special programming (iLogic) is required. I have used Inventor for many years yet this feature has not been added.
I ran into this a month ago now that we're exporting BOMs to an ERP system. Turns out you can set the unit of measure to "yd^3" but I did write this macro to help us go back and update old models. It's not commented and could really use cleaning up (the AddParameter sub doesn't need to be a sub here, but I had it from some other code so in the interest of saving time copy paste won out)
I understand the point you're looking for is not to need a macro so this doesn't really help you but if someone else finds your idea this might help them. I know this was much harder then I expected to get working. I figured I should have been able to simply set my Base Quantity in the Document Settings to my iProperty Volume and walk away but that isn't how it worked.
