Create an offset-pattern, similar to rectangular/circular pattern
Good day, Autodesk ! As i was trying to create something like a grid/grill for simplify the weigth and reduce some material from a 3D part, it came an ideea that can be able to create an offset pattern module  of a shape ( circle,square,rectangular, or any other shape from a sketch ) and not just create the simply offset, but also add the ideea of pattern of it, by adding the distance between them and number of elements patterned . What do you say about this ? for the begining the pattern could reffer to simple geometrical object as circle, rectangular, hexagon, lines, points . The offset pattern is similar to Centripeta  / centrifuga force  if i make a parralel to phisycs 😄 . it should combine : offset geometry+scale (maybe) +distance between the pattern elements created. OR TO NOT complicate the thigs, on SCALE module, you can add a COPY section  and an DISTANCE box ( or the scale factor box can remain but making another section like DISTANCE BETWEEN will help better, beside the Scale Factor )so the original geometry will remain and another will be created all this would be similar to the OFFSET - PATTERN ideea. Anyway, along all my explaining ideea i think you understood it .
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
