To create a 3D model from a 2D AutoCAD DWG underlay, it's necessary to insert multiple instances of the referenced AutoCAD file onto multiple planes in Inventor, then create multiple sketches - one for each 2D AutoCAD DWG underlay, and then project the DWG geometry into the sketch.
It would be a big time saver of we could copy and paste the Sketch which contains the projected geometry onto a new plane, and have Inventor automatically create a new instance of the referenced DWG file to support the projected geometry.
Layer settings in the referenced DWG instance would be the same as the original instance. We would still need to translate and crop the new instance.
Thanks for all your hard work.
Paul
