This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Constrain bolt to slot, Use Shift to select two geometries
Workflow:
Constrain/Insert.
First selection, Select bolt circle.
Second selection: select arc on slot,
Hold Shift, select other arc on slot.
Apply.
Bolt is positioned in the middle of the two arcs/circles.
7 Comments
al.popovich
Having suffered through a few weeks of using Solidworks, their "Slot" constraint (mate) is very nice. Suggest similar for Inventor.
nickolas_jaderas
This concept should be possible to do with all geometry...
Constrain something to the middle between two planes, something like the symmetry constraint, (but with this you cant select the same part)
AttilaFarkas
Hi Guys,
This function has been already implemented into Inventor for many years, just use the joint command instead of constrain.
nickolas_jaderas
AttilaFarkas
 Yeah, quite hard to hit the right spot, got it right after 30 seconds, and did not know why I succeeded 😉
I see the centermark light up, but is unable to make it stick...
Much easier to use the tool we have and is used to...
AttilaFarkas
No. Its easy. First select the point of the bolt, then move the cursor above the planar face containing the slot (dont click yet). Hold down the Ctrl and dont release it (it fix the face selection). Select the midpoint of the slot and click. Release the control. Select the slider type and if the direction is not correct then modify the direction with the align selection. You can also set the limits (+/-).
nickolas_jaderas
Yeah, actually super easy with the Ctrl method, seams you only have to select anywhere on the surface 🙂
Reminds me of the hidden ALT-insert-drag thing 🙂
4-5 inputs from user with Joint method.
6 inputs with my suggestion, however switching between Joint and Constrains is quite annoying.
lerskine24UR7
Can't use slots for bolted connections though.
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
