Constant chord width fillet
Hi, I wish Inventor has Constant Chord Width Fillet feature. Alias has it. Please add the feature to Inventor.
I found @JanHedlund4801 requested this feature few years ago (it's been archived https://forums.autodesk.com/t5/inventor-ideas/constant-fillet-width/idi-p/5899103). I think it's great idea to get fillet on edge that has same width in simple click. Meanwhile using the  variable fillet by setting different radius at the points on the edge to get the same chord width takes time too long.
10 Comments
When working with surfaces (or solids) it would be a real time saver if I could specify a constant width of a fillet.
I don't really care about what radius it is, as long as it's width is the same all over the part, and parts placed near by.
Trying to fix this with variable radius is to time consuming.
/Jan
DRoam
You might post this as a question in the Inventor General Discussion section (here) and see if the community can suggest an already existing method to do this. Several of the community members are extremely knowledgable and provide solutions to modeling questions like this one every day.
I can get the same resultat by sweeping a surface tube, split the surfaces, delet them and replace it with a lofted surface.
The command for constant with has been avaliable in Mechanical Desktop as far back as I can remember, havn't used it lately thou.
ahorwood
available in Alias, too bad AD took it out of our Ultimate package. I'll vote it up.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
insan.gunawan.st
My friend found it in Fusion 360.
And I knew we can sync AIV and F360,  but please add the feature to Inventor, will be great
binsar_z
@insan.gunawan.st You are correct, it is available in Fusion 360,
wondering why Fusion 360 feels like a bit superior than original Inventor, as it also has well integrated Simulation, CNC Programming, Generative design etc...  🤔.
nb
Is there a way to replicate the constant cord fillet in Inventor, without exporting and then bringing it back?
J_Fuelling
Observer
Just stopping by to say I would love if Inventor had chord length as a fillet option. I used to use it all the time in Fusion and would love to be able to do the same now that I only use Inventor.
