command to create Sheet Metal Stiffener / Guesset
Can we have a direct command to create stiffner in sheet metatal design?
12 Comments
Solid Edge does this quite easily. Wish Inventor would catch up on sheet metal.
janelson33
So I did some digging on the Inventor forum, and since 2006 your customers have been asking for this software functionality: Sheet Metal Gusset iFeatures. Well, here's another one wanting the same thing so I can stop hacking my files to display what I want.
Solidworks has had this since 2014 apparently, and the feature is not a hack like every forum link that I will provide for y'all explains. Every method(s) that people use to add the gusset into the Inventor files are just hacks, they won't work in a flat pattern?!........
I mean hell, if it CAN'T work at all, at least make a proper hack. For example, display the gusset as a point on the flat pattern. Then in that point, allow all the punch data to be extracted for a drawing file (especially .dxf files), using the same sort of special annotation feature button such as "Chamfer" or "Hole & Thread Feature" does.
These are common features for strengthening sheet metal design. Is there a good reason why the company is behind on supporting this? That's over 10 years that you've left people incapable of doing their jobs efficiently, on very, very pricey software....
References:
2006 Post
2011 Post
2015 Post
2017 Post
CBliss iFeatures
Tags (4)
inv.ideareview
Status changed to: Gathering Support
janelson33
Thanks for consolidating the listings, wouldn't it have been better to use the one that's spelled correctly? That's why I couldn't find it when I searched I think.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
Jim.Swain
Could you resurrect this idea?
janelson33
Agreed! +infinity
It would be nice if you could maybe through an unfolded sheet metal part and have it make a gusset with a few drop downs like: gusset height and angle...
[cid:[email protected]]
Still struggling with the lack of this feature...
Yes there are several other software platforms that have the simple command to make a stiffening gusset in sheet metal.
cole_fischer
Having this feature would help immensely on basically any structural sheet metal part.
