Show only
Search instead for
Just to be sure I understand... are you wanting to do this so you can select, say, Solids A, B, and C as Bases, and then select, say, solids D, E, and F as toolbodies, and end up with solids A-C which now ALL THREE have the geometry of Solids D-F a part of themselves? Is that the idea?
This idea has been implemented within Autodesk Inventor 2021. Window selection is now supported to select multiple toolbodies after the initial base is declared. Special thanks to everyone who cast a vote for it.
Hi Dan! Ben can step in if I’m off here, but I believe the intent of this idea is different. I believe the idea is about being able to select multiple bases to be affected by a cutting toolbody. Right now we can only select one base. The idea is to be able to have the selected toolbody(ies) cut from multiple bases rather than just one. Sort of like an extrusion can cut multiple bodies at once.
