What I want is make the hole like the one on the left , insted of the one on the right.
it very easy to do this in the workshop. I need to Spotface because the guide rail because of wear and tear over time and the Countersink so it autocenter for extra precision. in the workshop you can do this in one go .. but inventor it is a lot of extra work in both 2d and 3d to make it happen. and a lot you can forget to do
so simple an new hol feature with both Spotface and Countersink(3d) and create your our standard so you simple select the bolt , and all the need info as already plot in.. ofcause it should be possible to make change. and only need to use Hole and Thead to add one diamension on the 2d drawing to give the workshop all the information they need
