Colored selection text in PLACE command
When using the "Place" command in an assembly file when one right clicks to get the on screen commands, the "Rotate X 90", "Rotate Y 90" & "Rotate Z 90" command text should be the same color as the X, Y and Z arrows used on the XYZ icon. This would make using these commands selections more intuitive.
1 Comment
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that
pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
