Hi
This is a suggestion to extend the hole feature to optionally do both a Clearance Hole in one range of selected solids and a Tapped Hole in another range of selected solids, both respecting a common set of parameters. All in the same instance of the feature.
In the current version of the hole feature it is necessary to repeat the hole feature, and match their parameters manually. In turn the two features would have to be updated individually, eg. in case the size of the intended screw or bolt changes.
Cheers - Anders
