Clear iLogic Log Programatically
More and more I find that during code testing a session fills up the iLogic log and then I try to select and copy from it and Inventor will lock up and I will have to wait for it to read the entire file. This can take a very long time sometimes, and if i'm not careful I can crash Inventor at this point as it is froze up.
Being able to clear it programmatically would be a big help, so that as a routine kicks off, it wipes the log and starts fresh
3 Comments
WCrihfield
It might also be nice if the iLogic Log could be divided up into 'sections'.  Maybe one section per iLogic rule writing to it.  Or maybe give us the ability to start a new log section by code, and assign it a name or ID, then later be able to access that specific section(s) again by its name or ID, instead of the whole thing.  The way the Inventor.TransactionManager system works comes to mind as a similarity.  Or maybe 'bookmarks' or 'checkpoints' could work too, as long as we could jump straight to a specific section of the log, rather than accessing the whole thing.  Or maybe 'parallel' logs.
Curtis_W
Curtis_W
I'll take about any improvement to this at this point! 🙂
Yesterday I lost work twice, because I clicked the log file and tried to copy and it was so big it locked Inventor up... I don't have time to wait for it to take 3 -5 minutes to read/load the large file that occurs after repeated code tests over an hour or so of heavy log writing...or whatever it's trying to do, so I had to kill Inventor and just redo some work 😫 ... I save often but still... this should fixed so that we don't need to worry about this.
