Check surface normal without using Construction
At the moment, if you want to find out the normal direction of a surface you have to copy it to Construction and then use the Reverse Normal command. This is tedious if you just want to check it. Please add a button to the Inspect tab to Display Surface Normal.
Ideally you would be able to flip the normal without copying to the Construction environment, but I can see how this might be much harder to implement.
If you work with surface normals please see my related idea to be able to set surface normal using the Stitch command
https://forums.autodesk.com/t5/inventor-ideas/set-surface-normal-using-stitch/idi-p/7922862
1 Comment
Agree this is very useful especially if you have to make transitional constrains with surfaces
