Change icon of fully constraint parts in assembly
I hate to say it, but SolidWorks has different icons in the browser for fully constraint parts and parts that has some degrees of freedom left...
I would like to have that also within Inventor.
It is a usefull feature and (ex-) SolidWorks engineers ak me all the time, how in Inventor, they can easily see, if a part is fully constraint.
The "Degrees of Freedom" feature doesn't work with large assemblies. It would be nice, if you can see it in the browser.
See a suggestion how it can look in the attachment.
82 Comments
jingyi.liu
Hi Jimmy
Thanks for your feedback, I thought your request was very similar to below idea on icon for fully constrained component, the idea has been accepted.
https://forums.autodesk.com/t5/inventor-ideas/change-icon-of-fully-constraint-parts-in-assembly/idi-...
Jingyi
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
DRoam
@Discussion_Admin, can this idea be merged with the one jingyi linked to above?
wsseo
조립품에서 완전 구속 상태인지 불완전 구속상태인지 확인할 수 있는 표현 기능 추가를 요청드립니다.
Bing Transaltion:
We will ask you to add a representation feature to check whether the assembly is fully constrained or incomplete.
nthomasH8FXK
I would agree.  I've used another top level 3D modeling software for about 10 years and that is a such a beneficial feature, to see if the model is fully constrained.
I'd suggest another level, a glyph or icon in the feature tree indicating if a part is fully constrained or not.  This is a simple addition that the Inventor competition already does.
inv.ideareview
Status changed to: Gathering Support
Hi
Thanks for you feedback, there is a similar idea as below, that idea has been accepted, please cast your vote there.
This is the most confusing thread I've ever read - It's marked as accepted 5 years ago, but the status in the responses has gone like this:
Gathering Support
Accepted
Gathering Support (4 more times)
Archived
What happened?
Wauw. Started in 2013, still nothing done....Great
Yep, your IDEAS in action !!!!
hugo.trepanier
It's hard to understand that this idea was accepted since many year and I can't see change inside the newest Inventor and SP (2019.3). When we use the tool in the assembly productivity and use Degree of freedom Analysis Inventor can recognize which parts is fully constraint (0,0,0). Why its so hard to hard an icon in the browser that indicate all degres of freedom are constraint???
A certain Autodesk competitor who shall remain nameless includes a feature where an icon next to parts in the an assembly tree change when the part becomes fully constrained, allowing the user to quickly identify which parts are constrained and which are not. Please add this feature to Inventor, ideally with the added functionality that the icon could change depending on whether or not the part is fully constrained, part of a contact set, not constrained, etc.
Thank you.
david.beal
I was looking for information on the same type of constraint indicator and found this post back from 2013 for the same thing.
It was accepted back then but was never implemented?  Here we are 6 years later and still wanting the constraint indicator.  It is a really good idea and should have been implemented by now.
johan.degreef
It should be a lot of help if parts & subassemblies in the browser had another icon if not fully constrained. For example:
How many votes do we need?  I sure hope this get's addressed in some of the upcoming versions.
JelteDeJong
i created an addon with the purpose to address this issue. see:
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=6524519755338237990&appLang=en&os=Win64
0x3FA5
Hi.
Any news on this one?
gusi_cl
MrSmithtastic
Will this ever be implemented?
0x3FA5
MrSmithtastic,
Inventor 2040
