Capture iLogic Drawing Annotation Code Directly from Object
The current workflow for adding annotations with iLogic is quite good, but it is not always intuitive how to get the exact result concerning placement, addended text, etc.
It would be outstanding if we could right click on annotations such as dimensions, balloons, etc. and extract the code to add/create them just as they appear on the drawing, something as shown in these images and code examples.
Dim Sheet_1 = ThisDrawing.Sheets.ItemByName("Sheet:1")
Dim VIEW2 = Sheet_1.DrawingViews.ItemByName("VIEW2")
Dim genDims = Sheet_1.DrawingDimensions.GeneralDimensions
Dim Face0 = VIEW2.GetIntent("Face0")
Dim Face1 = VIEW2.GetIntent("Face1")
Dim Point1 = VIEW2.SheetPoint(1.2, 0.5)
Dim linDim1 = genDims.AddLinear("Dimension 1", Point1 , Face0, Face1)
linDim1.NativeEntity.Text.FormattedText = "<DimensionValue/> OA"
Dim VIEW1 = Sheet_1.DrawingViews.ItemByName("VIEW1")
Dim Pt1 = VIEW1.SheetPoint(1.4, 0.4)
Dim Face = VIEW1.GetIntent("BBBB", "Face1",
	intent := PointIntentEnum.kMidPointIntent, nearPoint := Pt1)
Dim balloon1 = Sheet_1.Balloons.Add("Balloon1", {Pt1}, Face)
4 Comments
swalton
I'd like to extend this idea to any Inventor command.  I find it hard to know where to start when I want to try to automate anything.  If Inventor would translate the UI actions I make into API calls so I can follow along, then it might be easier for a non-programmer like myself to develop custom automation.
Very good idea. My vote you have.
Or kind of code-recorder!
Pav3L
I would like something like that.
I think its kind of similar to what I use in Excel, in the developer tab "record macro". It records every user action done in a macro.
Tiffany_Hayden_
I don't know if any of you used the software "Intent" back in the day. But it had something very similar that you could capture code and have it write the code block for you. Very nifty. I vote!
