There is a set of value plot to be used always in Inventor.
However, Inventor, setting the value of the Plot is in conjunction with Windows, initialization is always.
So, there is inconvenience that every time, you must specify the settings each time you the Plot.
There is a Page Setup tab to set up a print value in Solid works,
You can take advantage of to save the value of print.
That is, as AutoCAD plot functions, features that were once used to allow continued use
Features may have been added.
