[BUG] API/iLogic - Leaders - creating or setting a GeometryIntent based on a FeatureControlFrame fails
When using the API to move the attachment point of leaders on a drawing with GeometryIntents the code will fail when the intent is a FeatureControlFrame.
Steps to reproduce:
Create the following VBA function: (The functions moves the attached leaderpoint 1 mm down)
Sub Bug_FeatureControlFrameAsIntent()
    Dim DrawDoc As DrawingDocument
    Set DrawDoc = ThisApplication.ActiveDocument
    Dim L As Leader
    Set L = DrawDoc.SelectSet(1).Leader
    Dim LeaderPoint As LeaderNode
    Set LeaderPoint = L.RootNode.ChildNodes(1)
    Dim AttachedGeometry As Object
    Set AttachedGeometry = LeaderPoint.AttachedEntity.Geometry
    Dim NewPoint As Point2d
    Set NewPoint = LeaderPoint.Position.Copy
    NewPoint.Y = NewPoint.Y - 0.1 'Move point 1 mm down on the sheet
    Dim NewIntent As GeometryIntent
    Set NewIntent = DrawDoc.ActiveSheet.CreateGeometryIntent(AttachedGeometry, NewPoint)
    LeaderPoint.AttachedEntity = NewIntent
End Sub
Place on your drawing items with a leader (Leader Text will do, but it works als with Feature Control Frame)
Make sure you attach them to vertical objects because the code move the point vertical and reattaches the leader
Select one item with a leader and run the function.
The function will throw an error when the leader is attached to a feature control frame.
