Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
BOM Sorting
BOM Sorting
Currently, the BOM can be sorted using a total of 3 columns; this need to be increased. Honestly, it should be expandable to as many sorts as needed, but even just 1 or 2 more would be incredible.
3 Comments
MKE_Howard
Can't you just use the column chooser?
msansom
@MKE_Howard The column chooser allows adding more columns that can be sorted individually, but I'm referring to sorting the BOM based off a combination of columns. Currently, when you click on the "Sort Items" button, the "Sort" window (shown below) pops up and you can sort the BOM using up to 3 columns. This isn't enough sorts for me to organize my BOM the way I need. They should change this to allow you to add additional sorts.
VahidKR3VG
Work Around is to Shift+Select on the Top of the BOM headers in the BOM to sort by more items. You can probably save it as a template, but I am not sure. You can test and report back. Cheers
