Block Feature in Sketch on Drawing Sheet (IDW/DWG)
Currently users can not create blocks in sketch on drawing sheet.
It would be a nice feature when working on sketch.
Can I expect to have it in the new updates of 2023 version or the next release (i.e. 2025)?
Thanks.
2 Comments
SReitberger
IMHO sketched symbols are similar to blocks in some way.
What would be the advantage of a block? Could you give an example where a block could be used (and a sketched symbol could not)?
Is it possible in your case to sketch in the ipt/iam and then make the sketch visible in idw? In this case, blocks could be used.
g_colombi2KRBH
For me too would be a great feature to have, couse a block in the sketch mode can be positioned precisely to the projected geometry of the 3d part, and from my understanding is not possible with sketch symbols.
Also, a block may be much more proficient to modify and adjust ( i'm thinking of legs of a machine that is sloped, and supporting legs with different height, that are copied and stretched.
