In Pro/Engineer, a series of quick Right Clicks prehighlights each item that is directly under your pointer from top (closest to the pointer) to bottom. You then need to Left-Click the prehighlighted feature to actually select it. Holding Ctrl then allows you to repeat and add features to the selection set, if desired.
If you were to then Right Click and hold for a slightly longer time, the shortcut menu then comes up, allowing you to modify the feature, etc.
This is a MUCH faster way of selecting hidden geometry, faces, features, etc., than the Inventor method of using the Select Other button, especially when working with multiple selections.
With Pro/Engineer, I can go Right, Left, Hold Control, Right, Right, Left, Right, Right, Right, Left and now have three overlaying or hidden features, surfaces, or edges selected, in less time than it takes to get to the Select Other command.
