Bendable Tubing with Ends
Currently Inventor is set up so you can create Tubing with Bends with couplings, which means you can connect tubing to tubing.
What my company needs to is to be ability to create styles that allow you to create a Tubing with Bends with Ends.  This would allow you can connect the tubing assembly to other fittings, just like what we have with the Flexible Hose.
This is important for us since the companies we sell to, their governments require them to use stainless steel tubing instead of flexible tubing in certain situation
Right now we have a work around but when you're creating 20, 30 or more Tube runs, it can be a pain.  In addition this is something Inventor should be able to do.
