Being able to render Point Clouds (LIDAR)
Inventor already accepts Point Clouds from Recap and other programs to use in desiging your models.
I would, however, like to be able to render the Point Cloud and the model at the same time IN inventor.
Yes. You can import both the Cloud and the Model in 3DS for instance, but that's inconvenient.
11 Comments
machiel.veldkamp
To clarify a bit. (was very busy before...)
So. What I'm working with is a large factory. For some sections of the building I have small sections that I have cropped and imported.
The point cloud density is now 1x1x1 mm.
So this gridspacing is great when you're viewing from far away and you have a bunch of points that kinda blend together.
But when viewed upclose, or zoomed in rather, the points apear smaller. This can be fixed by making the points apear themselves larger. This is already a function that is available in 3D Studio Max (which we also have installed but I don't like to use since I am not familiar with this software)
machiel.veldkamp
https://knowledge.autodesk.com/community/screencast/3f711ebb-5a39-42f6-8f81-757b39182eb4
I made a video. I don't remember to embed it here. Too much work
dgorsman
Just to clarify - when you say "render the point cloud ... IN inventor..." you mean... what?  To video or frames? Or are you referring to the on screen display?
machiel.veldkamp
I was initially refering to the inventor studio environment.
I use fixed viewpoints in the main assembly we have. So every time there's an update. People can regognise the location.
Point Clouds aren't visible in Inventor studio yet however.
Besides that. When zoomed in the voxels get too small. So being able to set a voxel size would be great.
h.schkorwaga
Inventor should be capabel to create meshes or similar from point clouds. Current situation is unacceptable...
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
t_fransman
Yes that would be nice. I agree rendering it in studio the PC just disappears, suspicious.
machiel.veldkamp
This idea is archived. see the above post to see how you can raise action once more.
Keipher_Ormesher
This is still relevant.  You can import point clouds into Inventor, but I cannot see a way to render them or use them in drawings.
Both would be very useful to cut down on modelling time or integrate information with other stakeholders.
JusticeSmith
is this still not possible? 8 years later??
