Batch Export
Batch Export
Would like to be able to Batch Export multiple files. Having to do it numerous times is time consuming. We do not have the resources to write a custom macro.
2 Comments
ChrisMitchell01
Depending on what you are trying to achieve the Task Scheduler will enable you to do batch exports - have you looked at that ?
http://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-08A6F75B-FBF4-4D48-BC50-5A581078ECC2
-Chris
abu-CAD
Batch Print & Export Pro on the Autodesk App Store does exactly this — batch export multiple Inventor drawings to DWF, DXF, PDF, or print all at once.
No custom macro needed. Drag your files, select formats, and it's done in seconds. Free 7-day trial:
https://marketplace.autodesk.com/apps/6b70363c-02fe-4dc4-9f62-66817e41e31f
