Forum: Retrieved Dimensions of Patterned Extrude Cut Circles Measured to Quadrants
@petestrycharske So I ran across an interesting issue the other day where a user extrude cut circles and then patterned them. When retrieving the dimensions in the model, it automatically measured the pattern spacing from the quadrant points.
Workaround:
You can edit Sketch2 and create a vertical line across the circle. Split the circle at the top and the bottom. Then edit Extrusion2 to make sure both halves are selected. Now, the pattern dimension will be retrieved from the centers.
