In the the drawings, I need to show levels of my machines from the ground floor. Where is possible, I use dimensions, but where isn't, I do it manually with inserting leader text, so text is not related to model. When change in the model occurs, leder text values are kept the same as before modification. So, I need to find all these leaders and modify them manually, but sometimes I don't find every one of them. So, drawings with errors are delivered to the customers and workers, which is bad. I wish to have a way to connect levels to the model geometry, or to refer to ground floor value in the drawing. This way it would be possible to place level indicator in the Top Views or Top Sections. Level should be automatically updated with the model update or ground floor value update.
