This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Automated Centerlines dialog - improve support for slots
Would it be possible to improve support for slot features in the Automated Centerline command?
It should support orthogonal, inclined, and curved slots.
Here are how centerlines are currently retrieved in 2016 for features created with the slot sketch tools.
undefined
Would it be useful to others if Inventor improved the retrieval and formatting of the centerlines?
undefined
Thank you for your consideration.
Jerry
6 Comments
And let there be a faster way to place a bolt in the middle of a slot.
Other CAD systems have an attachment point in the center of the slot.
Must be possible in Inventor as well.
Maarten Weers
Technical Specialist CAD EMEA - Parker Hannifin
The slot features should be model features like chamfer and hole, not sketch enhancements.
This new feature can contain a attachment point for bolts, pins etc which is placed in the middle and/or outer centers of the slot.
Maarten Weers
JBerns
Perhaps their behavior would be similar to an iFeature, but more convenient to access.
You would still want access to the slot sketch for constraining purposes and access to sketch parameters for creation associations.
- Jerry
dg2405
For automated slot-centerlines i've wrote some vba-Code:
Sub Mittellinie_auf_Langloch()
On Error GoTo Ende
Dim oDrwDoc As DrawingDocument
Set oDrwDoc = ThisApplication.ActiveDocument
Dim oCenterLine As Centerline
Dim oDrwCurve As DrawingCurve
'Zeichnungsansicht greifen
Dim oView As DrawingView
Set oView = ThisApplication.CommandManager.Pick(kDrawingViewFilter, "Zeichnungsansicht auswählen")
Dim oSheet As Sheet
Set oSheet = oView.Parent
'Alle Langlochkreissegmente in Collection
Dim oAllSlotArcsCollection As ObjectCollection
Set oAllSlotArcsCollection = ThisApplication.TransientObjects.CreateObjectCollection
For Each oDrwCurve In oView.DrawingCurves
    If oDrwCurve.CurveType = kCircularArcCurve Then
        If Round(oDrwCurve.StartPoint.DistanceTo(oDrwCurve.EndPoint), 3) = Round(2 * oDrwCurve.StartPoint.DistanceTo(oDrwCurve.CenterPoint), 3) Then
            Call oAllSlotArcsCollection.Add(oDrwCurve)
        End If
    End If
Next
'Durchschleifen un Mittellinien setzen
Dim oArcCurve As DrawingCurve
    If oDrwCurve.CurveType = kLineSegmentCurve Then
        Dim oSlotArcsCollection As ObjectCollection
        Set oSlotArcsCollection = ThisApplication.TransientObjects.CreateObjectCollection
        Dim oSlotIntentsCollection As ObjectCollection
        Set oSlotIntentsCollection = ThisApplication.TransientObjects.CreateObjectCollection
        For Each oArcCurve In oAllSlotArcsCollection
            If Round(oArcCurve.StartPoint.DistanceTo(oDrwCurve.StartPoint), 3) = 0 _
                Or Round(oArcCurve.StartPoint.DistanceTo(oDrwCurve.EndPoint), 3) = 0 _
                Or Round(oArcCurve.EndPoint.DistanceTo(oDrwCurve.StartPoint), 3) = 0 _
                Or Round(oArcCurve.EndPoint.DistanceTo(oDrwCurve.EndPoint), 3) = 0 Then
                Call oSlotIntentsCollection.Add(oSheet.CreateGeometryIntent(oArcCurve))
                Call oSlotArcsCollection.Add(oArcCurve)
            End If
        Next
        If oSlotArcsCollection.Count = 2 Then
            Dim CenterMarkCounter As Integer
            CenterMarkCounter = 0
            Dim oCenterMark As Centermark
            For Each oCenterMark In oSheet.Centermarks
                If Round(oSlotArcsCollection.Item(1).CenterPoint.DistanceTo(oCenterMark.Position), 3) = 0 Then CenterMarkCounter = CenterMarkCounter + 1
                If Round(oSlotArcsCollection.Item(2).CenterPoint.DistanceTo(oCenterMark.Position), 3) = 0 Then CenterMarkCounter = CenterMarkCounter + 1
            Next
            If CenterMarkCounter = 0 Then
                Call oSheet.Centerlines.Add(oSlotIntentsCollection)
            End If
        End If
    End If
Next
        Dim oSlotIntentsCollection2 As ObjectCollection
        Set oSlotIntentsCollection2 = ThisApplication.TransientObjects.CreateObjectCollection
        Dim oSlotCenterArcsCollection As ObjectCollection
        Set oSlotCenterArcsCollection = ThisApplication.TransientObjects.CreateObjectCollection
        Dim oSlotArcsCollection2 As ObjectCollection
        Set oSlotArcsCollection2 = ThisApplication.TransientObjects.CreateObjectCollection
                Call oSlotIntentsCollection2.Add(oSheet.CreateGeometryIntent(oArcCurve))
                Call oSlotArcsCollection2.Add(oArcCurve)
                Dim oDrwCurve2 As DrawingCurve
                For Each oDrwCurve2 In oView.DrawingCurves
                    If oDrwCurve2.CurveType = kCircularArcCurve Then
                        If Round(oDrwCurve.StartPoint.DistanceTo(oDrwCurve2.StartPoint), 3) <> 0 _
                            And Round(oDrwCurve.StartPoint.DistanceTo(oDrwCurve2.EndPoint), 3) <> 0 _
                            And Round(oDrwCurve.EndPoint.DistanceTo(oDrwCurve2.StartPoint), 3) <> 0 _
                            And Round(oDrwCurve.EndPoint.DistanceTo(oDrwCurve2.EndPoint), 3) <> 0 Then
                            If Round(oDrwCurve2.StartPoint.DistanceTo(oArcCurve.StartPoint), 3) = 0 _
                                Or Round(oDrwCurve2.StartPoint.DistanceTo(oArcCurve.EndPoint), 3) = 0 _
                                Or Round(oDrwCurve2.EndPoint.DistanceTo(oArcCurve.StartPoint), 3) = 0 _
                                Or Round(oDrwCurve2.EndPoint.DistanceTo(oArcCurve.EndPoint), 3) = 0 _
                                And Round(oDrwCurve2.CenterPoint.DistanceTo(oDrwCurve.CenterPoint), 3) = 0 Then
                                If oSlotCenterArcsCollection.Count = 0 Then
                                    Call oSlotCenterArcsCollection.Add(oDrwCurve)
                                    Call oSlotCenterArcsCollection.Add(oDrwCurve2)
                                    Dim oIntent As GeometryIntent
                                    Set oIntent = oSheet.CreateGeometryIntent(oDrwCurve)
                                End If
                            End If
                        End If
                    End If
                Next
            End If
        Next
        If oSlotCenterArcsCollection.Count = 2 Then
                If oSlotArcsCollection2.Item(1).CenterPoint.DistanceTo(oCenterMark.Position) = 0 Then CenterMarkCounter = CenterMarkCounter + 1
                If oSlotArcsCollection2.Item(2).CenterPoint.DistanceTo(oCenterMark.Position) = 0 Then CenterMarkCounter = CenterMarkCounter + 1
            Next
                Call oSheet.Centerlines.AddCenteredPattern(oIntent, oSlotIntentsCollection2, , , False)
                    If Round(oSlotCenterArcsCollection.Item(1).CenterPoint.DistanceTo(oCenterMark.Position), 3) = 0 Then oCenterMark.Delete
                Next
            End If
        End If
    End If
Next
Ende:
End Sub
dg2405
And here is Code for placing content-center parts on slots:
-Place a contentcenter part
-Run Code
-Select circular edge from contencenter part
-Select arc from slot
On every identic slot will be placed the contentcenter part.
Public Sub Scheibe_auf_Langloch()
    On Error Resume Next
    'Scheibe greifen
    Dim oScheibenKreis As EdgeProxy
    Set oScheibenKreis = ThisApplication.CommandManager.Pick(kPartEdgeCircularFilter, "Kreis von Normteil auswählen")
    'Occurrence ermitteln
    Dim oScheibeOcc As Inventor.ComponentOccurrence
    Set oScheibeOcc = oScheibenKreis.Parent.Parent
    'Fläche von Occurrence ermitteln
    Dim oNormteilFaceProxy As FaceProxy
    For Each oNormteilFaceProxy In oScheibenKreis.Faces
        If oNormteilFaceProxy.SurfaceType = kPlaneSurface Then Exit For
    Next
    'Rechtwinklige Ursprungsebenen ermitteln
    Dim oApp As Inventor.Application
    Set oApp = ThisApplication
    Dim oPerpendWorkPlaneProxy1 As WorkPlaneProxy
    Dim oPerpendWorkPlaneProxy2 As WorkPlaneProxy
    Dim oPlane1 As WorkPlane
    Dim oWorkPlaneProxy1 As WorkPlaneProxy
    Set oPlane1 = oScheibeOcc.Definition.WorkPlanes.Item(1)
    Call oScheibeOcc.CreateGeometryProxy(oPlane1, oWorkPlaneProxy1)
    Dim oPlane2 As WorkPlane
    Dim oWorkPlaneProxy2 As WorkPlaneProxy
    Set oPlane2 = oScheibeOcc.Definition.WorkPlanes.Item(2)
    Call oScheibeOcc.CreateGeometryProxy(oPlane2, oWorkPlaneProxy2)
    Dim oPlane3 As WorkPlane
    Dim oWorkPlaneProxy3 As WorkPlaneProxy
    Set oPlane3 = oScheibeOcc.Definition.WorkPlanes.Item(3)
    Call oScheibeOcc.CreateGeometryProxy(oPlane3, oWorkPlaneProxy3)
    If oApp.MeasureTools.GetAngle(oWorkPlaneProxy1, oNormteilFaceProxy) = 0 Then
        Set oPerpendWorkPlaneProxy1 = oWorkPlaneProxy2
        Set oPerpendWorkPlaneProxy2 = oWorkPlaneProxy3
    End If
    If oApp.MeasureTools.GetAngle(oWorkPlaneProxy2, oNormteilFaceProxy) = 0 Then
        Set oPerpendWorkPlaneProxy1 = oWorkPlaneProxy1
    End If
    If oApp.MeasureTools.GetAngle(oWorkPlaneProxy3, oNormteilFaceProxy) = 0 Then
        Set oPerpendWorkPlaneProxy2 = oWorkPlaneProxy2
    End If
    'LanglochArc greifen
    Dim oLanglochArc As EdgeProxy
    Set oLanglochArc = ThisApplication.CommandManager.Pick(kPartEdgeCircularFilter, "Kreissegement von Langloch auswählen")
    'Langlochradius
    Dim Langlochradius As Long
    Langlochradius = CLng(oLanglochArc.NativeObject.Geometry.Radius * 10000000)
    'Fläche von Langloch ermitteln
    Dim oLanglochFaceProxy As FaceProxy
    For Each oLanglochFaceProxy In oLanglochArc.Faces
        If oLanglochFaceProxy.SurfaceType = kPlaneSurface Then Exit For
    Next
    Dim oLanglochOcc As Inventor.ComponentOccurrence
    Set oLanglochOcc = oLanglochArc.Parent.Parent
    'Alle gleichen Flächen in Collection
    Dim oBodyFaceCol As FaceCollection
    Set oBodyFaceCol = ThisApplication.TransientObjects.CreateFaceCollection
    Dim oBodyFace As Face
    For Each oBodyFace In oLanglochFaceProxy.NativeObject.Parent.Faces
        If oApp.MeasureTools.GetAngle(oLanglochFaceProxy.NativeObject, oBodyFace) = 0 Then
            If oApp.MeasureTools.GetMinimumDistance(oLanglochFaceProxy.NativeObject, oBodyFace) = 0 Then
                Call oBodyFaceCol.Add(oBodyFace)
            End If
        End If
    Next
    'Auf Baugruppe zugreifen
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = ThisApplication.ActiveDocument
    Call oAsmDoc.SelectSet.Clear
    'Durchschleifen
    Dim oCircEdgeCol As EdgeCollection
    Set oCircEdgeCol = ThisApplication.TransientObjects.CreateEdgeCollection
    Dim oLineEdgeCol As EdgeCollection
    Set oLineEdgeCol = ThisApplication.TransientObjects.CreateEdgeCollection
    For Each oBodyFace In oBodyFaceCol
        Call oLanglochOcc.CreateGeometryProxy(oBodyFace, oLanglochFaceProxy)
        Dim oEdgeLoop As EdgeLoop
        For Each oEdgeLoop In oLanglochFaceProxy.EdgeLoops
            If Not oEdgeLoop.IsOuterEdgeLoop And oEdgeLoop.Edges.Count = 4 Then
                Dim oEdgeProxy As EdgeProxy
                For Each oEdgeProxy In oEdgeLoop.Edges
                    If oEdgeProxy.NativeObject.GeometryType = kCircularArcCurve Then Call oCircEdgeCol.Add(oEdgeProxy)
                    If oEdgeProxy.NativeObject.GeometryType = kLineSegmentCurve Then Call oLineEdgeCol.Add(oEdgeProxy)
                Next
                Dim AktuellerRadius As Long
                AktuellerRadius = CLng(oCircEdgeCol.Item(1).NativeObject.Geometry.Radius * 10000000)
                If oCircEdgeCol.Count = 2 And oCircEdgeCol.Item(1) = oCircEdgeCol.Item(2) And AktuellerRadius = Langlochradius Then
                    'Teil einfügen
                    Dim oFile As String
                    oFile = oScheibeOcc.Definition.Document.FullFileName
                    Dim oAsmCompDef As AssemblyComponentDefinition
                    Set oAsmCompDef = oAsmDoc.ComponentDefinition
                    Dim oTG As TransientGeometry
                    Set oTG = ThisApplication.TransientGeometry
                    Dim oMatrix As Matrix
                    Set oMatrix = oTG.CreateMatrix
                    Set oScheibeOcc = oAsmCompDef.Occurrences.Add(oFile, oMatrix)
                    'Fläche von Normteil ermitteln
                    Dim oNativeNormteilFaceProxy As Face
                    Set oNativeNormteilFaceProxy = oNormteilFaceProxy.NativeObject
                    Dim oFace As Face
                    For Each oFace In oScheibeOcc.Definition.SurfaceBodies.Item(1).Faces
                        If oFace Is oNativeNormteilFaceProxy Then
                             Exit For
                        End If
                    Next
                    'ProxyFläche von Normteil ermitteln
                    Dim oNewNormteilFaceProxy As FaceProxy
                    Call oScheibeOcc.CreateGeometryProxy(oFace, oNewNormteilFaceProxy)
                    'Rechtwinklige Normteilebenen ermitteln
                    Dim oNativePerpendWorkPlaneProxy1 As WorkPlane
                    Set oNativePerpendWorkPlaneProxy1 = oPerpendWorkPlaneProxy1.NativeObject
                    Dim oWorkplane1 As WorkPlane
                    For Each oWorkplane1 In oScheibeOcc.Definition.WorkPlanes
                        If oWorkplane1 Is oNativePerpendWorkPlaneProxy1 Then
                             Exit For
                        End If
                    Next
                    Dim oNewPerpendWorkPlaneProxy1 As WorkPlaneProxy
                    Call oScheibeOcc.CreateGeometryProxy(oWorkplane1, oNewPerpendWorkPlaneProxy1)
                    Dim oNativePerpendWorkPlaneProxy2 As WorkPlane
                    Set oNativePerpendWorkPlaneProxy2 = oPerpendWorkPlaneProxy2.NativeObject
                    Dim oWorkplane2 As WorkPlane
                    For Each oWorkplane2 In oScheibeOcc.Definition.WorkPlanes
                        If oWorkplane2 Is oNativePerpendWorkPlaneProxy2 Then
                             Exit For
                        End If
                    Next
                    Dim oNewPerpendWorkPlaneProxy2 As WorkPlaneProxy
                    Call oScheibeOcc.CreateGeometryProxy(oWorkplane2, oNewPerpendWorkPlaneProxy2)
                    'Abhängigkeit vergebn
                    Dim oDoc As Document
                    Set oDoc = oScheibeOcc.Definition.Document
                    If InStr(oDoc.PropertySets.Item("Design Tracking Properties").Item("Description").value, "Zylinderstift") Then
                        Call oAsmCompDef.Constraints.AddFlushConstraint(oNewNormteilFaceProxy, oLanglochFaceProxy, 0)
                    Else
                        Call oAsmCompDef.Constraints.AddMateConstraint(oNewNormteilFaceProxy, oLanglochFaceProxy, 0)
                    End If
                    Call oAsmCompDef.Constraints.AddMateConstraint(oNewPerpendWorkPlaneProxy1, oCircEdgeCol.Item(1), 0, kNoInference, kInferredPoint)
                    Call oAsmCompDef.Constraints.AddMateConstraint(oNewPerpendWorkPlaneProxy1, oCircEdgeCol.Item(2), 0, kNoInference, kInferredPoint)
                    Call oAsmCompDef.Constraints.AddMateConstraint(oNewPerpendWorkPlaneProxy2, oLineEdgeCol.Item(1), 0, kNoInference, kInferredPoint)
                End If
                oCircEdgeCol.Clear
                oLineEdgeCol.Clear
            End If
            If oEdgeLoop.IsOuterEdgeLoop And oEdgeLoop.Edges.Count = 4 Then
                If oLanglochOcc.Definition.Document.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then GoTo EndOuterEdgeLoop
                'Dim oEdgeProxy As EdgeProxy
                Next
                'Dim AktuellerRadius As Long
                    'Teil einfügen
                             Exit For
                        End If
                    Next
                             Exit For
                        End If
                    Next
                             Exit For
                        End If
                    Next
                    Call oAsmCompDef.Constraints.AddMateConstraint(oNewNormteilFaceProxy, oLanglochFaceProxy, 0.1)
                End If
                oCircEdgeCol.Clear
                oLineEdgeCol.Clear
EndOuterEdgeLoop:
            End If
        Next
    Next
Ende:
End Sub
DRoam
In addition to including slots in automated centerlines, it would be nice to be able to quickly create center marks for specific individual slots. For anyone who'd like to vote for that, here's a new idea asking for it: Center Mark for slots in drawings.
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
