Auto-correct (DXF) when export
If a sheet is produced with a laser-machine, then normally it would become not 100% correct, because the laser has some tolerances.
So it would be usefull if the dxf-file could be auto-corrected when exporting it with an user-defined value.
For example if the user sets the value to 0,1mm, then the outside-geometry would be made smaller (=> minus 0,1mm) and the inside-geometry (holes, threads, etc.) would be made bigger (=> plus 0,1mm)
In effect this is nothing else than the offset-function...
3 Comments
jletcher
Thomas I ran lasers for years seems to me your operator does not know how to run the laser. We have never had this issue ever. All lasers have an offset in the perameters you may want to look into that.
thom-g
OK, so we have to check this with our operators...
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. The product team continually reviews this forum aiming to deliver in the most impactful way we can based on voting. We also regularly examine the list to make sure it reflects the most current Ideas. As part of this process we archive old Ideas that haven’t received broad support. This ensures there is room for new Ideas to be reviewed by the community and for the most relevant and meaningful ones to gain votes.
This Idea is archived because it's been on the board for over a year and hasn't received many votes. If you want to raise it again and try to gain more support across the community, you're welcome to do so. Leveraging images, animated gifs or sample mock-ups can help convey concepts and generate more votes from other users. If you have questions or see a connection between this Idea and others that should be accounted for, please let us know.
- INV.IdeaReview
