Auto Center Marks for Circular patterns
It would be nice if we could add center marks to all holes in a circular pattern, without having to select all of them individually. I know you can use the centered pattern; however, you still have to select each hole individually, or the case below happens, where only the Holes you have actually selected have center marks. Being able to do a drag-to-select or select the circular pattern in the tree and auto apply center marks would be nice.
5 Comments
If you right click on the view and click 'automated center lines', a box will pop up and you can choose the circular pattern button and it creates all the center marks for you...It's a hidden gem!
thanks for the assistance this post can be deleted if need be
pasi.annila
Automated centerlines doesn't do well on many cases like patterned patterns so You get my vote anyway.
pasi.annila
sth
Dear All,
consider the behavior when holes are added or removed - currently we need to create all centerlines again with loss of all dimensions Smiley Sad. So we'd love if add / remove holes will be supported for the "centered pattern center lines" to reduce the efforts for changing them in our designs.
Cheers,
Thomas
