Assign dimension and text styles to certain sheets in an .idw
Add a setting to set certain sheets in a drawing to use a specified dimension and text style by default. For example, I create "dim style A" for "sheet A" and create "dim style B" for "sheet "B". If i begin working on "sheet A" with "dim style A" when i switch to "sheet B" my dimension style is still "dim style A" and I would have to manually change it to "dim style B". It would be alot smoother and worry free if "sheet A" uses "dim style A" by default whenever i activate that sheet. If not this then maybe a way to assign dimension and text styles to different sheet sizes.
