Hello. I recently found a problem with how the assembly tree sorts items when "Alpha Sort Component" is used. I have attached a screenshot showing this problem, with the error highlighted.
What seems to happen is that the sort function (*in the assembly tree only) recognizes '100' as a '10-0' number, rather than one above 99. These parts all have the same first digits, with the numbers after the dash denoting the next part number, then a description after the underscore. Everywhere else these parts are sorted, the numbers behave correctly (98, 99, 100, 101, etc).
I'd love to see this fixed in an upcoming update. Thank you!
