Assembly Pattern/Sweep components along a single path or guide rail(s)
Assembly Pattern/Sweep components along a single path or guide rail(s) in one operation rather than potential multiple rectangular or circular patterns. Also allow this pattern along irregular curves/splines.
3 Comments
swalton
The current workaround is to make a feature pattern along a curve in a part file.  Add that part file to the assembly, then make a component pattern that follows the feature pattern.
Jason.Rugg
@swalton Do you have an example file of this that I could take a look at? I have tried doing this and more often than not it fails. So I wonder if I am missing something, so if you have an assembly pattern I could look at that would be helpful.
swalton
I have one. I can't attach anything to an idea post, so I PMed you with it.
