Arrange Dimensions to centre
Using "Arrange" dimensions in Annotate never center's the dimensions that are updated. It does shift them to pre-determined offsets but seems to not try and get them in the centre at all. This has been a problem for a long time and I took me too long to post this problem.
4 Comments
m.verbunt
We use some iLogic code to do this.
Dim oDoc As DrawingDocument
oDoc = ThisDoc.Document
' Set a reference to the active sheet
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
Dim oDrawingDim As DrawingDimension
Dim oDrawingDims As DrawingDimensions
Dim oDimsToBeArranged As ObjectCollection
' Iterate over all dimensions in the drawing and
' center them if they are linear or angular.
' Add them to the ObjectCollection to be arranged
oDrawingDimensions = oSheet.DrawingDimensions
oDimsToBeArranged = ThisApplication.TransientObjects.CreateObjectCollection
question = MessageBox.Show("Would you like to center all dimensions?", "Arrange",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
          'set condition based on answer
            If question = vbYes Then
For Each oDrawingDim In oDrawingDimensions
	       oDrawingDim.CenterText
    If TypeOf oDrawingDim Is LinearGeneralDimension Then
'       oDrawingDim.CenterText
       oDimsToBeArranged.Add(oDrawingDim)
    End If
	Next
			Else If question = vbNo Then
    End If
	Next
			End If
If oDimsToBeArranged.Count > 0 Then
	oDrawingDimensions.Arrange(oDimsToBeArranged)
End If
MarcellW
Hi m.Verbunt
This is quite a work-around!
Thank you kindly!
s_klausR9UFR
You can solve the problem directly in your template:
Unfortunately, my Inventor is set to German, but I hope you can find the setting via the screenshot.
Best regards
MarcellW
Hi Klaus
Thank you for this! I managed to change it accordingly. I will test it going forward
