Arrange dimension !
Arrange dimension !
An error in the behavior of the Arrange Dimensions command needs to be corrected. After the "Group chain dimension"
 is grouped, this dimension should acquire the properties of a linear dimension. And it aligns as linear.
This error is very difficult to be productive. There have been several attempts to solve this problem here
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/is-it-possible-to-automatically-arrange...
and here
https://forums.autodesk.com/t5/inventor-forum/arrange-dimensions/m-p/10758612
But Autodesk cannot do without goodwill, and this problem cannot be solved.
Thanks for your understanding
6 Comments
Yijiang.Cai
Status changed to: Under Review
Many thanks to post this idea to us, and it has been tracked as [INVGEN-58548].
robertast
@Yijiang.Cai   Thank you very much. And does this mean that this perennial bug will be fixed? Will there be another 10 to think about?
ernis
These general dimensions also need to be adjusted. According to the rule
 Rule:
vvvxxvvv333
@Yijiang.Cai  None of the "gruop dimension" respond to Arrange. And this is not correct. Everything should work according to the chosen style!
robertast
If the Inventor team can fix the sizing errors. I think it would be advisable to make such a choice in the parameters.
ernis
Yes, I think this would also solve the problem of transferring annotations to the drawing. The initial idea with annotations was good, but the implementation is not complete. When you transfer them to a blueprint, you get a complete mess.  😕   It takes a long time to fix, it is easier to re-size all the dimensions.
