API: localized values
Add the ability to read and change localized property values to the API.
There are many properties that are language specific (mainly the DisplayName property).
A good example would be the material and appearance assets.
Today, you can not change these localized properties at once: you must close Inventor and restart it with the language you want.
possible implementation:
Inventor.Application m_application = ...; // the current inventor application object
Inventor.Asset appearance = ...; // the inventor object for which the localized property shall be read / changed
string propertyName = "DisplayName"; // name of the property that shall be read / changed
string languageCode = "de"; // ISO 639-1 language code
// read localized text
string localizedText = m_application.LanguageTools.GetLocalizedValue(appearance, propertyName, languageCode);
// change localized text
m_application.LanguageTools.SetLocalizedValue(appearance, propertyName, languageCode, "Blabla");
