Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Amplify hole command using 1 feature
Sometimes it's necessary to create a hole with a counterbore ore spotface at both sides.
Now I need to use hole command twice.
It would be great if it its possible to tick a button like below.
6 Comments
Even this idea is an option to make a counterbore or spotface at the backside.
dan_inv09
Put me down for pipe tap on both ends (with spotface/counterbore options too).
Agreed. Just found an instance in which I need a set of counterbores on opposite ends of a hole feature. Also, it would be beneficial to be able to pick if the counterbores are stacked (think step-down drill bit) or if they are opposed (think barbell). I'm voting for this one to be included in a service pack or new version!
Also, side note, how would one notate a double-counterbored hole (opposite ends OR stacked, I'd like to know both)?
DRoam
Isn't this a duplicate of this idea: Hole Feature - Top and Bottom of Hole Options? Could the two ideas and Kudos be merged?
dusan.naus.trz
dusan.naus.trz
