Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Allow users to Pattern Work Features in Assemblies
Work Features can be used with the pattern tools in the Part environment, but not at the Assembly level/environment.
Sometimes it is useful to draw axes and points at the assembly level and use those for a pattern, rather than features/components only.
For example, if you do not want to have holes made at the assembly level, but want to pattern bolts going through SOME (not all) of the holes patterned at the part level, you could simply pattern axes through some of their centers (starting with any hole), then use those to pattern your bolts. Right now we are limited to copy a pattern from the part level onto the assembly level, then suppressing/deleting additional unwanted occurrences.
13 Comments
It would be nice if patterns would work with work axis and work planes.
Now fore some reason this objects can not be patterned.
Cris.
jletcher
It does........
How did you do that?
I can not select axis or plane for pattern component.
Please post sample file.
Are this done in part file?
I need this in assembly.
Cris.
jletcher
This is a part no where in your idea did you state in an assembly.. Smiley Wink
You are correct it cannot be done in assembly. The pattern tool in assembly is for parts and assemblies.
 May I ask why you do it?
I ap placing numerous parts in an assembly and to do that I need to create reference geometry of axis and planes (in order not to constrain to other parts because whan I after replace components constrains are lost).
Cris.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
Des_Seals
Could you add a way to pattern work planes in an assembly the same way we're able to do it with parts
Tags (2)
jack.starrGDXYE
Found out today, this is not possible.
ProductivCADUser
I also wonders this.
Usually, patterns in assemblies are possible with common CAD systems (not definied by a subitem (Part level)). If necessary, a sketch must be created in the assembly which defines the pattern.
Is this really not possible in Inventor or is it just a lack of knowledge?
nlongden8DZVL
Observer
A useful feature would be to be able to pattern work planes or axes like any other component. Currently they do not seem to be selectable using the pattern tool.
MattH_Work
Been able to pattern Work plane & Axes for as long as I can remember.
Can be selected either onscreen or via browser
r
dba78
Whilst it is implemented in part environment (Feature-Pattern), I guess he's missing it in Assembly-Environment.
In Assembly-Environment you can pattern a component, and since Work-Geometry is not a component, there is no patterning of it in assembly context. So maybe you make a part, do your pattern there and insert it in an assembly in order to use the geometry.
