Allow Inventor Sketchblocks to be edited in AutoCAD
I have complex geometry in AutoCAD, which I can copy to Inventor as a sketchblock, and use this for feature creation. It would be great if I was able to modify this geometry using the tools in AutoCAD, because making a similar modification with the sketching tools in Inventor on an unconstrained sketch would be near impossible to do.
AutoCAD is great for manipulating geometry that is not constrained in any way. With the 'Modify' tools and the ability to modify the UCS, I can make manipulations very quickly.
These same Modify tools in the Inventor sketch environment are near useless on unconstrained geometry, and using the Precise Input option is a complete nightmare.
2 Comments
inv.ideareview
Thanks for sharing your Idea. The product team continually reviews this forum aiming to deliver in the most impactful way we can based on voting. We also regularly examine the list to make sure it reflects the most current Ideas. As part of this process we archive old Ideas that haven’t received broad support.
This ensures there is room for new Ideas to be reviewed by the community and for the most relevant and meaningful ones to gain votes. This Idea is archived because it's been on the board for over a year and hasn't received many votes. If you want to raise it again and try to gain more support across the community, you're welcome to do so. Leveraging images, animated gifs or sample mock-ups can help convey concepts and generate more votes from other users. If you have questions or see a connection between this Idea and others that should be accounted for, please let us know.
INV.IdeaReview
inv.ideareview
Status changed to: Archived
