We often design lifting equipment, and the need to know how a piece of equipment will hang from a lift point is very important.
Currently is we want to show a piece of equipment hanging properly, we need to constrain to a user made workpoint or axis, and redefine this geometry as the equipment design changes.
It would be a real benefit if we could instead have the shackle aligned with the COG as it would in real life.
It would also help, if we could then set the view in the drawing to use that aligning workplane to adjust the view rotation so the lift point is always above the COG.
![Use COG.png Use COG.png](https://forums.autodesk.com/t5/image/serverpage/image-id/192112i48E943EB251B0BFD/image-size/original?v=mpbl-1&px=-1)
