If I create a harness under a model state, why do I need to convert the cable harness to be adaptive under, quote: "The top level assembly Model State must be set to "[Primary]" before a nailboard drawing can be made." ?
I should be able to create the Nailboard from whatever Model State the cable was created in. The way some commands work makes using the cable function real clunky.
The cable module needs to be upgraded to keep up with some of the new functionality in the core Inventor..
