Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Allow Balloons to work with Work Points
Allow the usage of a work point to gain the GeometryIntent that is supplied to Sheet.Balloons.Add(ObjectCollection).  Currently you must supply a Drawing Curve which requires user interaction.  For fully automated drawings, the best option would be to use work points which are currently being used in Leader Notes, Linear Dimensions, Ordinate Dimensions, etc.  Another possible option would be to supply geometry intent points and a component reference.  The component reference would allow for the linking of the Inventor BOM Id to the balloon.
More info from the forum here:
https://forums.autodesk.com/t5/inventor-customization/unable-to-create-balloon-from-workpoint/m-p/86...
2 Comments
W_Barnett
I have no idea why this isn't supported.  Even the alternative suggestion of "referencing the model" in the balloon code is a fantastic work-around that should be extremely easy to implement.  I'm shocked that it's also been 5 years since this was posted and it still hasn't been added.
Yijiang.Cai
Many thanks for posting the idea, and tracked as [INVGEN-75805]
