Currently there is no way to change the orientation of an applied image without creating a duplicate appearance with custom defined rotation in each one. There are many surface appearance images that are orientation dependent (such as wood flooring, brick, metal mesh, brushed surfaces, etc.). It sure would improve rendering and surfaces if you could control the alignment and rotation of an image applied to a surface.
