Adjustable field cuts
I have the same part that get field cut to various different lengths. it is a bit time consuming to use and extruded cut in assembly for each of these field cuts. It would be nice to have and adjustable extruded cut that could be placed in the subassembly but could control the length of and individual instance in an upper assembly. Similar to a Dynamic block in AutoCAD
1 Comment
You can use Model States
