I would like to create a chamfer as I represent with a sweep in the pictures below.
The sweep’s method is this one:
- Create an offset surface.
- Create a 3D line at the intersection of this surface and the solid.
- Create the sketch and generate sweep with the 3D line guide.
- Split the body with the sweep face.
However, I can’t use this method because it creates a small gap. Indeed, the reference should be the faces from above and not the shifted 3D line as I did.
Therefore, I would like to have a chamfer option that could do something like that.
Currently our customer uses the chamfer function “O1 X 02” in Creo to model it.
