adding model parameters to hole note and other feature notes
Add option for additional model parameters to hole note similar to regular text box. I want to pull in the dimension for my bolt circle, but the only way I can do this is to fat finger the dimension in.
1 Comment
scott.mainwaring
Observer
@chris_blessing I've requested this from our support guys and they said it's not possible in Inventor!
I used to use Creo and in that you could insert the parameter by putting an '&' before the model parameter number (d24 for example) so in your example it would look like "ON &d24 B.C". It would be so much easier to use with the capability of inserting model paramters in the same way as Creo. Plus when I insert the dimension as you've shown in your secon image, we currecntly work with a comma as a decimal point and using this method changes the comma to a full stop so it stands out on the drawing as being different.
