This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Adding custom BOM filter.
Please add an option to add a new custom filter in the "Define Filter Item" section in the Filter Settings dialog box in the Parts List editor. The selection options should be any standard Field and any custom fields generated in the iPart.
10 Comments
AJR1977
Correction, this should read as "Adding custom PARTS LIST" filter.
Hola. El problema es algún campo que no te aparece?
AJR1977
Correct. Only 5 predefined filters are available.
-Ballooned Items Only.
-Item Number Range.
-Purchased Items.
-Standard Content.
-View Representation:  This filter can get extremely tedious to isolate a particular type of part across multiple sub-assemblies.
Hola, disculpa la tardanza de respuesta he tenido unos días de fiesta. Sobre los campos de "PART LIST", es posible personalizar las listas. ¿Conoces como poner los campos personalizados?
AJR1977
Again, there are only 5 filter Fields available, and I am asking for an option to add a new custom filter in the "Define Filter Item" pull down list. I have custom columns in the Parts List that are associated with the parts and i would like to filter with this and standard available properties.
Ok, mañana te mando un video donde se puede ver como agregar campos personalizados. ME PUEDES DECIR UN EJEMPLO DE PARAMETRO PERSONALIZADO QUE NECESITES?
AJR1977
There is a "Manufacturer" field in the Parts list, in the screen shot above. This is a custom field.
There is also a "CATEGORY" field in the Parts List as well. This is a standard field in inventor.
Neither show up as filter.
Thanks for any help.
Adjunto el video donde puedes ver como poner los parámetros personalizados. Ten en cuenta las siguientes instrucciones.
  1. Selecciona en propiedades las casillas
  2. Ves ha iPropertis para llamar las propiedades, pero sobre todo pon el nombre igual, sin errores.
  3. Después fíjate bien como las inserto.
  4. Avísame si no puedes ver el video
Cualquier cosa estoy por el foro, escríbeme. Si esto te sirve por favor selecciona solución y dale, para que los demás lo puedan ver. Espero que sea lo que pides.
Video parámetro personalizado
AJR1977
Thank you for trying but your solutions do not relate to the original post.
Uwe_Lindner
YES, User need a BOM / Partlist Filter inside IDW or IAM!
Please integrated this at Stileditor!
2024-01-11 15_41_27-Autodesk Inventor Professional 2024.png2024-01-11 15_39_16-Bauteilliste_ ENG-000051.iam ([Primär]).png
