I'm on version 2021 and I'm not sure if this is available in the upcoming 2024 but thought I would ask. Currently to select a point 2D I have to use this code.
Call msgbox("Select a point on a sheet to place new view...", "View Placement")
Dim getPoint As New clsGetPoint
Dim oPoint2d As Point2d: Set oPoint2d = getPoint.GetDrawingPoint("Select a point on a sheet to place new view...", kLeftMouseButton, kCursorBuiltInArrow)
The issue with this is the prompt doesn't work in the get point class. And a message box has to be added to tell the user what to do. So I would like to see this added to the Command Manager Pick option.
Example:
Dim oPoint2d
Set oPoint2d= ThisApplication.CommandManager.Pick(kDrawingPoint2DFilter, "Select a point on any sheet for placement...")
I'm using this for user-selected placement on any sheet on the drawing set. If this was available I wouldn't have to use a message box to tell the user what to do and it would be just part of the workflow.
