"Add iLogic/API access to the 'Exclude from Nesting' property on sheet metal flat patterns, so it can be set programmatically across multiple parts at once — for example via an assembly-level iLogic rule. Currently this must be done manually part by part, which is very time consuming on large assemblies. Ideally this should also be linkable to a Yes/No custom iProperty so the BOM can reflect the nesting status automatically."
