Show only
Search instead for
By the way... if anyone now finds it very confusing trying to follow the 4-5 threads/conversations that have now been merged into one, please consider voting for this following idea in the Community IdeaStation: When Ideas are merged, show which thread comments were originally on.
Cody, as Curtis indicated the Inventor Team actively reviews the many Ideas generated within this forum. It is no small task to conduct admin work in cleaning up duplicates & preventing votes from being split.
Curtis, you are too kind. I appreciate the related link. I took action and merged the Idea into this one as they were in fact duplicate requests. Likewise the votes were merged. Missed you at AU this year. Cheers.
To both of you & previous comment authors - thanks for your efforts and contributions toward perfecting Inventor. The entire Inventor Engineering team greatly appreciates your time & attention to our Ideas forums. We are doing our best, however thanks to everyone here, we have no shortage of Ideas to work on & potentially implement. Finest Regards - Dan
Actually, I meant a second (or more) different drill diameters and depths in the same dialog (not including the port forming nor tapping as they are separate iFeatures).
I really wish Autodesk would fix this, so that we do not have to use iFeatures to create the correct holes as machined.
Drillbits is used, and for a 6mm countersunk screw, the outer diameter is 12,4. It would be nice if the counterbore depth was set default to the correct depth value, but was possible to override as well.
In Inventor 2019, the hole concept changed why it was not included? This theme has enough of votes. How much is still needed? Is it so hard to program?
It's been 4 years that this has been under future consideration and it has existed on all major competitor platforms for longer than that; please add this functionality.
