Add function Share Sketch for Adaptive Sketch
9 Comments
DRoam
There's currently a restriction where a shared sketch cannot be made Adaptive (and an Adaptive sketch cannot be shared).
This has been asked about and discussed many times before (just search the General Discussion area for "adaptive shared sketch"), and while it's possible to conceive of some situations where a shared adaptive sketch could result in relationship conflicts at the Assembly level (conflicting constraints applied to the same geometry of an adaptive sketch), I do not believe it is possible for this to result in any kind of cyclical dependency or other dangerous result.
Along with implementing this, it's also necessary to allow making only a sketch Adaptive and not any of its consuming features. Currently this is not possible and leads to undesirable results. For example, if we only want a sketch to be adaptive, we are forced to also make its consuming Extrusion adaptive--but now the length of that extrusion is free to be adapted even if we don't want it to. Leaving the extrusion un-adaptive, and adapting the sketch by constraining directly to it in the assembly (which we can already do) would be much more robust.
Extending that logic, we should also be able to make a feature Adaptive without making its consumed sketch Adaptive. This way we can, for example, adapt an extrusion's length without inadvertently adapting its sketched profile.
Basically, the adaptivity of a sketch and its consuming feature(s) should be independent.
Tags (3)
DRoam
Other Adaptivity improvements you can vote for:
  1. Fix Constraint-driven Adaptivity, Projected-geometry Adaptivity, and Copy Object adaptivity
  2. Add measurement parameters
DRoam
Correction: I was wrong in saying that we cannot independently make a Sketch and its consuming feature Adaptive. This can be accomplished by right-clicking on the consuming feature and selecting "Properties", and then we can check which inputs to make Adaptive (Sketch, Parameters, or From/To Planes).
However, this is un-intuitive, convoluted, time-consuming, and unnecessary. We should simply be able to right-click on the Feature OR sketch and say "Adaptive" and control the Adaptivity directly from those features themselves. If I make the consuming Feature adaptive, only its Parameters are adaptive. If I make the Sketch adaptive, the Sketch is adaptive. If I make the from or to planes for the Extrusion adaptive, those planes are adaptive. Simple as that. I should not have to control these from the consuming feature's "Properties" box.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
DRoam
Hi @inv.ideareview, I know this Idea was archived but a new one was created not too long ago that has several more votes. Could my votes be merged into that one? It's here: Add function Share Sketch for Adaptive Sketch.
inv.ideareview
@DRoam I have moved your idea to this one, and merge all the kudos.
inv.ideareview
This has been tracked as [INVGEN-28242], which will be investigated.
DRoam
Great! Thanks!
