At the moment Extrude works perpendicular to the plane of the sketch. I would like a direction option (similar to that used when creating patterns) so that the Extrude can be along any straight line or axis that is not parallel to the sketch plane.
Sweep can be used to achieve a similar effect- but you cannot use an axis as a sweep path, and the sweep ends up the same length as the sweep path. With a direction option in Extrude, you would still be able to specify 'Distance' or 'To' limits.
