Add Axonometric views
There is a standard view named: "Isometric". I suggest that view Trimetric and Dimetric can be added.
1 Comment
Indeed, isometry cannot be used for parts that have faces and edges at an angle of 45 degrees to the axes.
When creating a base view, the viewing angle can be changed (including using iLogic).
But to create a visual image of a part with a cutout, it is necessary to be able to obtain a dimetric image in a projection relationship with the parent view (with the choice of the axonometry type by RMB)!
